Cell Phones Logo
Cindy Arauz Posted on Feb 17, 2020
Can't send or receive texts, I get 'Free Msg: Unable to send message-Message Blocking is active.' How do I deactivate? Phone is an LG900GHL
amanullah
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 11, 2020
amanullah
Contributor
Level 1:
Answers
Questions
0
Helped
465
Points
5
To confirm that text messaging is enabled on your account, go to the Device settings page for your phone and make sure that "Can send/receive text messages" is "Enabled". If there is no edit icon at the top of the Messages section (i.e. you can't update your text messagingsettings) then the number is not active
2 Related Answers
txslim55
txslim55
  • 1104 Answers
  • Posted on Aug 13, 2015
SOURCE: free msg:unable to send message-message blocking is active help me remove this message
Free msg unable to send message message blocking is active YouTube
Bill Boyd
  • 53816 Answers
  • Posted on Nov 16, 2015
SOURCE: I received this message after sending a text to someone.Free Msg: Receiver ********** unable to receive message - Message Blocking is active. What's this mean?
it means that the receiver has blocked you and will not receive any communications from you
two options
1 talk on the phone and ask why
2 meet face to face and ask why
When i send a text it says message blockingis active
To confirm that text messaging is enabled on your account, go to the device settings page for your phone and make sure that "Can send/receive text messages" is "Enabled". ... If someone texting you is getting a "Message Blocking Active" error, this may also mean that you don't have text messaging enabled. message blockingis active Google Search
Feb 03, 2018 • Cell Phones
two options
Nov 16, 2015 • Cell Phones
Unable to send and recieve picture messages
hi
firstly contact your operator and request for sending you the mms activation settings once you receive them as a message save them on the phone now you are ready to send and receive MMS messages
now to the part of sending an MMS
go to messages click on the
  • menu then New then MMS
  • now key in the addresse in the TO part and in the msg body
  • go to select insert Picture/ Video to insert a picture or video from your gallery
  • similarly if you want to add text select the text
  • also the same for audio
you can select all or any of the picture/ text/ audio and send as an MMS
hope this helped
cheers
PS: if this has been of any help pls rate the solution
Can't send text message. "unable to send message"
check your message centre number..If its edited or deleted..u cant send or receive any messages..contact your operator for tat number..
1helpful
2answers
I can't send any message or recive
How can I use the messaging features on my Motorola phone? space.gif space.gif answer.gif To send a text message:
  • Enter your Message menu
  • Scroll to Create Message and Select
  • In the To: field, either enter a telephone number**, e-mail address**, or Browse your Phonebook, Received or Dialed Calls list.
  • Enter your message in the MSG: field
  • Select done when you have completed the To: and MSG: fields
  • Confirm that you would like to send the message now
Please note that text messaging is a service provided by your cellular service provider and you must subscribe to this service to have the capability to send text messages. Certain carriers may require alternate instructions.
**Please contact your carrier for further information on these services, and to ensure they support sending to both a telephone number and/or e-mail address.
To send a text message - Select Menu, Messages, Create Message, and then New TXT Msg
<a href=""http://motorola.custhelp.com/cgi-bin/motorola.cfg/php/enduser/std_adp.php?p_sid=Id42qGph&p_lva=4061&p_faqid=4064"" target=""_self"">To send a multimedia message -Select M, Messages, Create Message, and then New PIX Msg
To Insert Objects In Text Message while composing a text message - Select Menu, and then Insert
To use MMS Template open an MMS template with preloaded media - Select M, Messages, Create Message, and then PIX Templates
To read a new text or multimedia message that you have received - Press Read (Right Soft Key).
To Store Message Objects - Go to a multimedia message slide, or highlight an object in a letterand select Menu, and then Store
To send or create a quick note message - Select Menu, Messages, and then Quick Notes
To view sent messages - Select Menu, Messages, and then Outbox
To read received messages - Select Menu, Messages, and then Inbox
Tip: Press Menu to perform various operations on the message.
To view messages saved in drafts folder - Select Menu, Messages, and then Drafts
To delete all messages or only messages from the Outbox or drafts folder: Select Menu,; Messages, and then Cleanup Messages
3answers
I can't send sms
ok first thing u do is go to the network provider then ask them if your sms is in active.... most of the problem like this is from the network provider....example network provider PTI. VIRIZON .PT&T etc.
Nokia 6070
actually your network service provider gives you message center number. call their customer care to get the msg center no. put it in msg center box.. and everything will work fine.
1helpful
Cannot 'SEND' text messages.
as i think the MESSAGE CENTER NUMBER you must change by asking your network operator ...
1. call to customer care of ur network operator
2. ask for the message center number..
3. store it in it by going to message settings and message center number ..
then try your sms will start going..................
SMS unable to send messages
Just Try either of the following ....
  1. Try checking the SMSC (Message Center Number) number configured on your phone. If the Message Centre number is not configured or wrong then you will not be able to send..but you can receive.
  2. Check... is there any setting called Inbox Setup in Message menu, then Text msg Setup -> Use GPRS -> NO
With Regards,
TPV
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
