Sometimes I notice lots of leaves in basket. But when I turn pump off to clean it, all the leaves disappear. Is there a way to stop that so I can properly remove the leaves?
Therefore, it's essential to avoid causing harm to water. The most obvious and effective is using the cover to keep twigs, leaves, and soil from getting in. Here are a few additional tips we recommend.
Install a gazebo or the cover over your spa or hot tub.
Prune the trees around them and rake them regularly.
When you discover even a few leaves in the water, take them out right away.
Clean the surface of your water regularly, and then use an air or pool vacuum to remove any debris that has fallen to the bottom.
Make sure to clean and maintain the skimmer's tank every two or three days during the week during the fall.
The effort you've put into this tumble to avoid regarding your hot tub, swimming pool, or spa will result in lower upkeep costs overall and a faster, easier revisiting of your normal usage when the temperature begins to warm again. We're available all the time to help with equipment, hardware, and master assistance for all of your spa, hot tub, and pool-cleaning requirements.
you can use the SOLAR POOL VACUUM CLEANER
Try closing the inlet valve to the pump https://aromacc.com/
Isolate the strainer before turning the pump off.
SOURCE: How to Clean Pump Strainer basket
Turn the swimming pool pump off and wait for the water to drain from the strainer basket. You want to make sure that the pump is completely off before you proceed. Remove the screws or any items securing the lid of the strainer basket. Open the lid and pull out the strainer basket. Vacuum the strainer basket or scoop out any debris. You may want to run clear water through the basket to ensure you removed all debris. Feel toward the impeller and remove any clogs or obstructions preventing the impeller from working properly. Check the o-ring under the cover of the pump strainer housing. You may need to use a silicon lubricant to ensure a water-tight seal. Put the strainer basket back into the pump strainer housing and pour some water into the basket. Replace the lid and secure it in place. Turn the swimming pool pump on and check for proper pressure. If your pressure doesn't register, you may need to troubleshoot to find the problem.
SOURCE: my pentair controller will not shut the filter pump off
Chances are that you have a bad relay, but the problem could be the main logic board. If there is a spare relay in the box switch all the wires from the pump relay onto the spare. Remember to shut off the breaker, and also you will need to change the wires on the top of the relay too, or you will have to do some reprogramming.
SOURCE: pentair whisperflo pump will not turn on
See if you can manually operate each pump. I suspect the problem is not with the pumps themselves. Track the control from the pumps to the motherboard, which I suspect. Whatever it is, it has all the pumps in common with it. Maybe just a simple control switch that is exposed to the elements.
SOURCE: I have a Pentair Intelliflo pump system and lately
Your pipe could be clogged or you may have a clog in the impeller. Check the pump basket and if it is cracked then it is probally in the impeller and you may be able to reach it with a screwdriver and needlenose. If you have a crack in the skimmer basket it could be in the line and you can check this by putting a kitchen sponge in the skimmer and if it comes out in the pump the line is clear. If it is clogged you may be able to clear it with a flush bag you can get at any hardware store. If that dosn't do it you will need to get a pro. Good luck.
SOURCE: pentair pool pump strainer basket has a lot of air
either you have a suction side air leak or the pump is too large for the plumbing and is cavitating.
If your pool pump is acting sluggish it may simply be a build up of debris inside the impeller. Cleaning it is simple if you know how.
Step 1 - Check the Impeller
You can check the impeller for clogs by opening the clear cover that is on the strainer basket. Then place your garden hose into the basket and turn it on high. The water should disappear immediately. If it does not, you may have a clog.
Step 2 - Turn off the Power to the Pump
Before actually removing the clog from your pool pump impeller you will need to turn off the power to it. Remove the basket and use a finger to reach into the hole behind the basket to feel for any debris. If it is clogged, go to step 3.
Step 3 - Disconnect the Pump and Motor
Disconnect the pump and motor from the plumbing. Depending upon the make and model of your pool pump you may be able to skip this step. The motor usually just slides away from the pump. Take the pump apart by removing the plastic cover over the motor. This cover generally has several small screws holding it on. Once the cover is removed you will easily be able to see the clog in the pool pump impeller. Just use your fingers or a coat hanger to clean it out. Put everything back together. Once you have it cleaned out you can put the cover back on and put it all back together. Problem solved.
Step 4 - Remove the Plastic Cover
Step 5 - Remove and Clean the Impeller
Step 6 - Clean
