SOURCE: Polaroid LCD TV Symptom dead
The ware to buy information will be hard to come by hence that manufacture for this product does not use a part number on every single part when servicing the unit. Thus I can recommend where to take it and whom to call for more information since this is a unit that i personally do not repair for my clients anymore due to the aftermarket of their parts and how expensive it is getting them ETC. Here is one solution find someone on Ebay.com that is saling this TV dirt cheap and take the parts from it at your own risk! or you can go the manufacture route by calling this number 1-866-289-5168
I know you came here looking for part numbers and more help then this we understand as experts but to tell you to do something that can harm you or go beyond our scope to get these part numbers, because the part in this unit don't go by that would not help you and us and the cost of the assistance would thus go up surpassing the $9.99. I only can diagnose and check on a solution based on your problem, Yes Fixya does have solutions that do Fix but in the case we can only recommend and I would encourage you to rate my assistance based only on recommendations to solve a solution only,
Thank You
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: how to get 48V output. I do not have Sun 480
One place offer DC power 6V to 600v http://www.us.tdk-lambda.com/hp/default_lvgoog.asp?gclid=COGvyYGd96UCFcjsKgodqA0ZpA
2nd place http://www.matsusada.com/dc/ You may understand offerings better than I.
Most promising based on your need http://www.powersupplydepot.com/pssearch.asp?searchtype1=1&search1=48&action=Search
Hope you find what you need.
SOURCE: MY INVERTOR MICROTEK DOESNT TRANSFER
the good way is u change to new inverter will solve your problems
SOURCE: hi there, i have a baird lcd model
there is 2 problems that makes this tv have standby fault.. so here they are,!
1.)main av board ---the 8 leg eeprom loses programing just under LVD CABLE TO SCREEN -£14.99 from a guy or if you can program yourself 4.99 for the flash to reprogram,.
2.)POWER SUPPLY FAULT IS MLT199TL PSU. (UA4)AREA, SG3525AN (16 leg) Regulating pulse width modulator.
the first fault all votage at psu will be there ,, 5v / 12v / 24v
the second fault psu will have 5v standby but no 12v or 24v this will stop the secondary from fireing up.. hope this helps.
SOURCE: Su -kam inverter model 850 is no out put supply for battery
"Parama Sukkam". Keep it always with you.
We are extremely sorry if
you have been inconvenienced through a Su-kam product. However, we
pride ourselves on prompt and effective customer service. Please
provide us with your name, contact number and address.
Please give us the complaint number and date as well and we
assure you to look into the matter at the earliest. Mail us at
[email protected],
We would do our best to resolve your grievance at the earliest.
Hoping to hear from you soon.
Sarita
Su-kam Executive
