If you're referring to the 200bt portable speaker set, this isnt possible. Car stereos are only designed for input over bluetooth not output. Now if it really important to you, you can use a line level adapter to tap into the rear speakers of your vehicle, take that output and plug it into your speakers with an aux cord, or if you have an after market radio you can use RCA cables and a jack adapter to do the same. If you must bluetooth (eg. out of vehicle operation of speakers) buy a cheap bluetooth output adapter (shark makes one) use a small cigarette lighter inverter to power it, and then you can plug your aux jack into it and bluetooth to a speaker set outside of the car. If you use this in conjunction with the speakers car there will be a delay between those speakers and your bluetooth speakers.
SOURCE: Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
I am assuming you are trying to pair iSound BT200.
See Page 6&8 of the ISOUND BT 200 User Manual
During the first time set-up, you must hold the
power/phone button down until you hear a voice say
"Power on" then followed by "Ready for pairing" in order
to sync your device to Bluetooth. After the initial pairing,
you can let go of the power/phone button after you hear
"Power on".
When a user is connected and the BT-200 is o , press ff
and hold for at least 5 seconds to unpair on Bluetooth
(allow another user to connect)
Also check the
Kenwood DDX616 Instruction Manual Bluetooth Unit Connection Bluetooth...
Kenwood DDX6019 Service Manual
