SOURCE: where do i locate the thermostat on my 94 scoupe?
Follow top radiator hose and it will lead directly to thermostat housing. Housing should have 3 bolts on it. Thermostat is under it.
Testimonial: "Thank you "
SOURCE: I need to replace the lcd in my harmony 880 remote
If Logitech cannot assist you with this, you can pick up a replacement LCD screen for about $25 on Ebay. It is a very easy fix. The screen is connected to the logic board with a simple ribbon cable. The grey top of the ribbon cable connector is gently lifted up and off and then 4 pressure-fitted tabs are simply squeezed to lift the LCD panel off the board. Good Luck!
SOURCE: need to locate a owners manual for a 2004 fleetwood wilderness advantage2952bs fifth wheel
Contact the manufacturer and provide them the Model number. If it is still in print they can provide you a copy for a fee.
I''m replying almost a year later, but this may help others who are having this problem. There seem to be a lot of problems with the tip over switch in the Comfort Zone radiator heaters (this is the switch at the very top, inside the panel, above the thermostat). I had the same problem- no heat, switches weren't lighting up. I bypassed the tip over switch (we have never tipped over one of our radiator heaters, so it's not an issue) and connected the switch wires with a wire nut and then further secured the wire nut with electrical tape. Now the heater works as it should again.
