All lights blink if I try any other program and it does not operate.
Check what are the program option in your gadget. Generally there will be two options one is NORMAL 55° (without pre-wash) and other is UNIVERSAL 55° or 65° (with a pre-wash).
Just try the first one. If it works then the second option has some problem but you can ensure that machine is otherwise working.
SOURCE: All lights are flashing including Pre Def, Timer,
Not sure the make and model of your equipment you have there but sounds to me like your control board is trying to tell you it is bad.
SOURCE: DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
SOURCE: warning lights flashing for Anti flood system
The bottom "Y" 3 point hose at the bottom connected to main motor is of poor quality and does have 3 wire clamps. The hose does perforate and small pin hole causes water at the bottom to trigger the anti flood system with warning lights flashing and pump motor on ...
