1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
Wanting to lessen the power of your flash with under exposing your picture/subject? Want to add natural light bounce to your subject and lessen shadows? Wanting to have a pop-up flash diffuser without spending a dime?How about removing shadow cast when doing some macro shots? If your answer to these questions are YES, then time to read this DIY guide. This should be easy to follow and the material(s) needed should be available in your home. First, let's briefly discuss what a diffuser is. Adiffuser lessens the strong/ harsh light coming from your camera's built-in pop-upflash, creating a softer and distributes the light evenly on your picture. There are lots of pop up diffusers out there and are relatively cheap. However here's one that I've tried and tested and worked fine for me. Take the cap of your empty roll-on(deo) place it with your hand, right at the front of the pop-up flash(in it's popped out position). Then take a picture using flash. Try it with and w/o the cap to see the difference. Not impressed? Try it first and explore new ways of getting better pictures.
White shadow or white lines may occur if the light was too bright when you take the picture, especially in strong sun light. Have you turn off the flash light when you taking those picture ? If you haven't, then you should try to turn off your camera flash light manually. And I must remind you not to take a picture with your lens faced the sun light or other light (lamp etc) directly. Even if you take a picture outdoors, try to make your lens shaded by something, you can even use your own shadow to shade them.
hi, first of all replace all the three crt base socket of ur tv's three crt guns. also check the line output transformer (LOT). my be its insulation have some problem that's why you hear a noise. noise of the high voltage leakage . if so u have to replace the LOT. ok
This problems is also parts of tv convergence board have dead 2 STK convergence ICS and some or all the resistors dead too.This problems the 2 STK and some or all it resistors are completely dead that why u only have red flashing light and chirping sound only.If your tv have any life function left of the tv convergence board u would have only mis alignments of colors R,G,B lines,have colors shadows or 3D pictures look alike.The shop,will cost like $300-350 to get the tv convergence board fixed also fixed this problems too.
