Thank you for reading the At Your Service blog. Please make sure the machine is plugged into a dedicated outlet with no surge protector or power strip. If the problem continues in a dedicated outlet then turn the machine off and unplug the network cable. Turn the machine back on with the network cable still disconnected. If the machine comes on properly then there is an issue with the network. If it still loops consider contacting consider contacting your local support centre for additional assistance.
Testimonial: "I try it still do the same thing"
SOURCE: xerox 7655 can it borderless print
No it's fisically not possible. There will always be an edge.
Try to print on a bigger piece of paper and cut it.
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
