1. First remove the backplate from the BUP2 by undoing the two small screws at the base of the unit and lift out from the bottom so that the two lugs at the top disengage from their positions. 2. Prior to installing onto the backplate, insert the battery into the battery tray and ensure that positive + and negative - are correctly installed. The battery is a non-rechargeable lithium cell and in the event of power failure will protect your programme instructions for up to 365 continuous days of power loss. 3. The BUP2 is factory set to provide 2 on/off switching periods per day and each day will be the same, i.e. daily operation. To select the other styles of switching you will have to alter the dip switches which are to be found at the bottom rear of the unit into the relevant position for the style of operation you require.
Testimonial: "Thank you Fahad. - that is most useful."
Thanks to the users
http://musicha.net/
