Hi nick, there could be a problem with the unit wiring or with the speakers connected to the unit. Firstly Have your unit independantely bench tested, if all is okay then you know the problem is with your spk wiring or with the speakers.
If there are any speakers that you know that are not working, then isolate them and recheck the sound.
if the unit is found to be faulty then best to hand it to a repair technician.
cheers.
SOURCE: changing the time pioneer DEN2000MP
The solution that worked for
me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
SOURCE: im looking for a wiring diagram for pioneer deh
http://safemanuals.com/annexe_1_PIONEER_DEH-P3550MP-_E.htm
Here's your manual. hope this helps
SOURCE: how do i remove my bmw e46 head unit?
The removal instructions should be on here
www.fitaudio.com
Testimonial: "thank you! Exactly what i needed. didnt know where to start! "
SOURCE: How do I set the clock on my Pioneer DEH-1900MP
Turn the unit off with SOURCE, then push and hold SOURCE until it powers up and the hour flashes... Then use the up/down directional buttons to adjust hour, and left/right directional to move to minute.
SOURCE: How do I remove xenon headlight unit on bmw e46
Just a thought, behind the front bumper are the securing hardware. Bumper needs to be removed so you can access the fasteners.
