Drills Logo
Pedro Lion Posted on Feb 07, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SKILL MODEL 6225 3/8" DRILL FROZEN REVERSE - Drills
john h
Level 3:
Top Expert:
  • Master 29,494 Answers
  • Posted on Apr 11, 2020
john h
Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7558264
Points
193449
Reverse switch failure
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jun 25, 2009
SOURCE: remove a chuck from a skill drill
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Uncscrew screw CLOCKWISE until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Why does drill only rotate in the remove position
All questions need 'make model (what it is)' as the first 3 words.
It is likely to be the selector, Undo-Lock-Clockwise, or it is the gearbox or switching mechanism, depending on type.
With make and model not stated, you can look it up
make model only works in reverse
Jul 21, 2023 • Drills
1helpful
I have a mastercraft industrial reversible drill. Model number 1540. Looking for a replacement handle with the power trigger and reverse switch. Anyone know where I can get replacement parts?
this picture of the drill is familiar or similar to a "skill" made drill
talk with a service agent for skill, B&D woulf machines and you may get a cross match or even a handle from a failed drill
Jul 23, 2015 • Drills
3answers
Where is the reverse switch on my black & decker 1/4 7004 drill type 1
The now vintage B&D model 7004 type 1 was a single-speed, non-reversible drill. There is no reverse switch.
I want to install the driver & pc suite for mt 6225
you should have specified the brand and model of your mobile to give the exact driver and pc suite.
Anyways!!
here is the link where you can choose and select the best mt 6225 driver for your model.
http://search.4shared.com/q/ABA/10/mt+6225
- it has 5 pages, just scroll from that pages and you will find what you are looking for.
Please rate my answer.
Thanks
I have a skill table saw model 3400 type 2. The
I would check to see that ID of the blade arbor matches the OD of the motor arbor, and you are not missing an adapter ring. Then I would get some acetone and a wire brush clean all surfaces where the blade seats. This is also good practice for Jacobs chucks on drills, that allow the drill bits to spin.
Jim
4helpful
Remove a chuck from a skill drill
Jun 24, 2009 • Drills
Need to repair a screwdriver drill. (Skil) Can you reccomend a place that can do this? Local preferably
Skill repair center are all over check for location at Skill web site
Jun 11, 2009 • Drills
2answers
The chuck no longer spins on my drill
Hi your best chance is to try ebay for one with the motor gone.
Other than that best you can do is buy another drill the same so you will have a spare battery.
You could try Skill for a gear but it probably will be the price of a new drill.
Top Drills Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
