Https://www.youtube.com/watch?v=FVuLgS5TPXs
https://www.youtube.com/watch?v=e3J5HWzk9aM
https://www.youtube.com/watch?v=cDSy4BQDeL4
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
SOURCE: the zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
sewman7
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
SOURCE: Needle stop up/down no longer works on Viking 118
sometimes the bobbin winder gets left closed, and that will make the machine run slowly and with no up/down button.
SOURCE: Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
