SOURCE: I refilled HP 88 cartridge but printer (Officejet
The chip on the cartridge needs to be reset. You can find replacement chips on the internet but they cost about half as much as a new cartridge. Also, if you filled the cartridge incorrectly you can get air in the ink lines of your printer which will make it unable to print that color. Overall, I would recommend getting refills from Cartridge World. They always reset the chip, take care of the mess of filling for you, cost less than new cartridges, and are 100% guaranteed to work.
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
SOURCE: OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
SOURCE: HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
SOURCE: HOW TO RESET 920 INK
FYI,
you cannot reset the ink it self.
If your using an HP refilled ink cartridge the warranty of your printer will be void.
you need to contact HP right away to purchase new ink cartridges.
If the cartridge has been refilled or remanufactured, 'Low on Ink' or 'Ink Alert' messages may be inaccurate or display incorrectly.
