SOURCE: Included lithium ion battery pack
Yes. Both cameras will only accept the Panasonic CGR-B/202A1B lithium ion battery pack. This special battery pack gives up to 100 minutes of use or 200 shots (based on the Fine mode, one shot with flash every 30 seconds).
SOURCE: Lithium ion battery pack
SOURCE: I require a battery ,
Please check the following link its a very good site to purchase battery in UK...
http://www.abattery.org.uk/
Thank you..
Regards!!..
SOURCE: explosion of a lithium ion battery
this is also called reverse charging.
Reverse charging, which damages batteries, is when a rechargeable battery is recharged with its polarity reversed. Reverse charging can occur under a number of circumstances, the two most important being:
SOURCE: are all 18650 rechargeable lithium-ion battery cells the same mah and volt?
Nominal 3.7 Volts.
2200-3400 mAH depends on chemistry and other factors..
List of battery sizes
