Cell Phones Logo
David Rummel Posted on Feb 04, 2020
I'm using an Android phone, with the GPS locator turned on.HuntStand says it can't find this device's location. What next?
Darylle Vaughn C. Alecha
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Feb 08, 2020
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
1148
Points
18
Hi. You need to check if the app has permission to use the location services by your phone. To grant permission to app to use location (It depends on Android Phone used), Samsung: Go to Settings>Biometrics and Security>scroll down and look for Location> Turn it ON. There you can see the Apps that can use the location services.
5 Related Answers
Anonymous
  • Posted on Aug 16, 2007
SOURCE: My phone wont locate my LG bluetooth.
Just because your phones Bluetooth option is turned to on doesn't mean it's searching. I would try going in to your device history and clicking on new device while your Bluetooth is in pairing mode.
Thx_nb
  • 242 Answers
  • Posted on May 08, 2008
SOURCE: HTC P3300 GPS not showing correct location
Most GPS systems have some inaccuracies.
The accuracy of you GPS system depends on your location, the number of satellites available on your location, if you are inside a building or in open field. Also standing between buildings increases inaccuracy.
So most of the time there is a deviation from your location. An inaccuracy of 30-50 meters is not xtremely bad for a GPS receiver in your phone.
Try to go to a place without buildings, trees close around you, best is to do this with a clear sky, and give the GPS receiver some time to find satellites and calculate it's position. Now the inaccuracy should be no more than about 20 meters.
I don't know the quality of the receiver in your HTC, but I think a accuracy of 20 meters should be possible.
Please post some feedback: where are you when you get inaccuracy of 50 meters? what's the inaccuracy when you are in open field?
Good luck
Anonymous
  • 158 Answers
  • Posted on Sep 20, 2008
SOURCE: no gps device
Sometimes it can take a TomTom many minutes to obtain satellites. To give it a chance and to test it make sure you have a clear 180 degree view to the south ( that's if you are in the northern hemisphere ) . Its to the north if you are in the southern hemisphere.
So, put the TomTom with it's back facing the equator ( all the GPS satellites are above the equator in an arc ) it's almost straight up in fact but towards the equator.
If you switch on , let it boot up , then tap the screen near the bottom right where you see a bar graph . ( see photo's and finger indicates where to tap position )
The screen will change to another screen and again you should have the bar graph on right hand side with a battery symbol either below or above. once again tap the bar graph and a larger STATUS screen should appear. You should be able to see the TomTom scanning for satellites . Any it receives will be GREY but grey ones are not yet locked on. If any of the bars on the TomTom get a fix or lock on they will turn BLUE . Only when the TomTom has 3 or more BLUE satellites can it present a fix on your location. If none of the bars on the graph ever turn BLUE then you have a faulty TomTom or possibly corrupted data on the SD card. If you get ANY of the bars turn BLUE then it's likely your TomTom is working OK but is just having difficulty locking onto any satellites. You might have to wait a while or move location.
Once the TomTom gets a fix , even if you turn it off then on again it will remember what satellites it was locked onto before so it should not need to scan again and should find the satellites real quick or at least quicker. See photographs below for the 3 stages to go through to check status.
( NOTE : The photograph shows a TomTom ONE v2 but almost all models of TomTom show similar screens ) See last photo where one of the bars is GREY , this shows it's receiving that satellite but it's not strong enough to get a fix from it. The last bar shows the TomTom knows there is a satellite there but currently has no signal from it. The BLUE bars show good reception and fixes on those satellites.
I do hope this helps solve your problem but if not then please revisit this forum and post any questions again and i'll see if I can help.
Please remember to rate my comments and recommendations if you have found them useful at all by clicking on the coloured diamonds on this page.
Anonymous
  • Posted on Dec 07, 2008
SOURCE: Garmin Nuvi GPS won't acquire satellites
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Anonymous
  • 1550 Answers
  • Posted on Jan 22, 2009
SOURCE: New Nuvi 200 will turn on briefly then turn off.
You need to charge your gps from any external charger and check whether screen is working properly .
Also do firmware update for your gps .
By updating firmware your problem can be fixed .
My Huntstand app doesn't work right after iPhone update. It won't let me turn on my location.
you have to wait for a new update, or try to backup your information then do the system restore through iTunes. There must an issue happened while installing the latest update.
Nov 18, 2018 • Cell Phones
tip
How to fake your android device gps location to any place you prefer(rooted...
1. Install the app Fake gps from playstore (or just google it)
2. set the pointer to any location on earth (you can also type manually the coordinates).
3. select the "set GPS Location" button.
3.Your gps location have now been faked and this fake location will be accessible to all the messengers and other apps you are using. https://play.google.com/store/apps/details?id=com.lexa.fakegps
on May 27, 2015 • Android Apps
7answers
What are the types of tracking devices?
GPS tracking system for vehicles can be of two types, depending on whether you need the vehicle position in real-time, or do you need the vehicle tracking data after the vehicle has travelled. Based on the requirements, there are two types of vehicle tracking that are available. They are:-
Active: The active GPS vehicle tracking devices are used to transfer the positioning data real-time to a close range wireless network device, like a phone with a Bluetooth.
Passive: Passive GPS vehicle tracking devices do not transfer the data real-time, but stores them for later use.
Article Source :
2answers
How do I track and get gps location on a cell phone for free when all I know is the number?
On an iPhone you have a Free App to download called Find iPhone.
Generally this is used for locating a lost or stolen iPhone, using another iPhone or Computer and with the ability to remotely play a sound to help locate the device or Delete all the Data on that iPhone remotely.
If you have 2 iPhones or more in a family and they share the same Apple ID Account that you use to purchase Apps (through iTunes) and to Manage & Backup your data & Apps. If both iPhones use the same Apple ID & Password then the "Find iPhone" App can be used to check and see the GPS position of the other iPhone on a map.
The tracking is not saveable as a file. Also www.icloud.com can be used to log in and see the location of all devices in the family (on the same Apple Account).
There is also an App called Find Friends that allows you to track friends current location but it does require & request their permission when first used.
You could also get a free App and install it on the other persons iPhone and simply have it running in the background to remember all GPS location data during a period of time. e.g. a "Pedometer" to track a persons movements. You would require access to the iPhone at some point to recover that data by plugging in to a computer using iTunes to recover the location data. Running some GPS Apps in the background will noticeably reduce the battery as all GPS tracking devices do.
Figure out the details by installing the Pedometer or iTrack App on your own phone first.
TJ
Jun 29, 2014 • Cell Phones
STOLEN PHONE
Hello, there is one application that an Android native, is called Android Device Manager. This app allow you to track, call and erase or lock your phone's data. There is one thing though, it needed to be active in order to work. But you can give it a try.
Do a search for Android Device Manager, it's usually the first one in Google search. After opening the site, type in your log in information (google account to which your phone was activated with).
Once the phone is with in Wi_fi range or is active with internet, you should be able to pin point the location of the phone.
As posted, the phone must have some kind of connection to get internet or data enable, otherwise, it just won't work.
This only works with Android phones.
Turn off gps
my gps is gone fromm screen
Jan 04, 2014 • GPS
GPS problem. I recently got my first Android phone and I am very happy with it. Recently I have discovered one problem in my Apollo: i can't get the GPS to work. Is there something I have to switch...
GPS isn't on by default (or you'd see yourbattery drain even faster).
Check whether GPS is on by going to
Settings, Location and Security,Use GPS satellites
If the box on the right doesn't have a green check in it, GPS is off.
Touch to turn it on.
Many programs will turn GPS on automatically. Check the settings for the navigationprogram you're using.
You might also want to look at a free app called GPS Test.
There are also apps such as Quick Settings that will let you turn GPS on andoff without going deep into the settings menu.
1helpful
3answers
I have a verizon droid 2 phone and my exboyfriend keeps tracking me how can I stop him from tracking my location with this phone
turning on the phones' GPS feature also turns on the tracking your every move.
Your can track "family members" without downloading and installing the "Family Member Locater" app
onto your Android 2 cellular telephone.
the Android 2 phone users manual:
https://store.verizonwireless.com/imgs/phones/userguide/Droid 2 User Guide.pdf
recommend you download this .PDF file and install the (free) Adobe reader to view it.
from www.adobe.com
To hide your location (from the above manual)
1. press Menu
2 press "Latitude"
this displays your "Friends List"
3. highlight your "Friend" by whom you no longer want to share your location
4. press "Menu"
5. press "Edit Privacy Settings"
6. press "Hide Your Location"
that ought to do it.
I need to locate where is my stolen cellular phone through GPS
Your phone can be located by triangulating the signal, in my country, only police have the jurisdiction to track phones. However this is not normal practice for something as trivial as a small theft.
The GPS device in the phone is only active on demand, meaning its not turned on unless the GPS software is started on the phone itself.
The IMEI number can be changed using a computer.
Try videocalling your phone, see if the thief answers =)
In the future you might want to install a security software pack on your S60 device, this locks the phone after a sim change, you can lock your phone by sending sms to it, set off alarms, etc.
Top Android Cell Phones Experts
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Steve Sweetleaf
Steve Sweetleaf
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
