If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
SOURCE: Black line on Panasonic Plasma
go here and follow, it will work!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: red line down right and left side of 42" LG plasma.
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the left top left
corner of the display window. It will make search easy. Some times, the ads
attached with each posts both at the right and bottom, might help you to find
the availability of spare parts. There are more than 640 posts to different
brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
