Televison & Video Logo
Andre Fauteux Posted on Feb 03, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to change my mainboard of my sony bravda model KDL-37L4000 Do you still buy it , I have one of the hdmi ports fail, the other work fine
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Feb 12, 2020
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008483
Points
237762
After the replacement of the main board; a software update might be necessary to any TV. Contact any service technician, of do it yourself, if you know how to do it. Or Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
5 Related Answers
Geoff Millar
  • Posted on Jan 31, 2007
SOURCE: sony kdl-40s2000
I have had an extremely similar problem with my Comcast Motorola DVR and Sony Bravia with HDMI connection. For months I would lose picture/keep sound when changing from a non-HD to an HD channel. The solution that I found is that there is a setting in the cable box setup that will likely fix your issue. Turn off your cable box leaving the TV on. Quickly press the Menu button on your remote to get into the Box setup. Make sure that 4:3 Override is set to "Off" instead of 480i. I believe this will solve your problem.
ginko
Ginko
  • 19396 Answers
  • Posted on Jul 26, 2009
SOURCE: change voltage from 120v to 240v sony bravia
I think that Sony Bravia are sold with dual voltage, 110V and 220V. All 220V devices work also on British 240V network.
If an electronic device is not compatible with the 240V/220V network, then the PSU must be replaced.
In your case the unit should be dual voltage, compatible with 220/240V networks. Just ensure checking the user manual, or the tag at the back of TV.
All you need in that case is an adapter that can be purchased at any local electrical shop (eg. Curry's if you are in UK).
Regards.
Anonymous
  • 1768 Answers
  • Posted on Feb 05, 2010
SOURCE: sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Anonymous
  • Posted on Mar 21, 2010
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Anonymous
  • Posted on Apr 01, 2010
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Sony Bravia KDL-55BX520 HDMI ports won't work but the A/Vports t
Either the HDM firmware or the circuit board will be faulty. Connect it with an other known good HDMI cable, and make sure that the fault is not with the connecting cable.
My sony hdtv hdmi broke not working
Either buy a new board or take a HDMI port off of something non working and see if it lines up with the solder points.
The av and hdmi loggo at top right hand corner
hit the display button on remote should turn it off
1helpful
2answers
161helpful
4answers
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
1helpful
2answers
Change voltage from 120v to 240v sony bravia 37L4000
Regards.
Can i change ntsc system to multi system on my sony tv BRAVIA KDL-37L4000
It is not designed to be changed over. Even if it was, it would probably cost more to do it than what it would be worth.
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just...
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
