Most dryers have a belt motor switch, when the belt breaks or is removed, the idler pulley has been removed or replaced then the switch will shut motor power off. Check for spring tension in idler pulley. also check power cord terminal block for voltage at the prongs. you may also have a blown thermal fuse check it .. usually located on blower. see pics
I REPLACED IDLER PULLY ON SAMSUNG DRYER #DV40J3000 - beltswitch-dryer-lint-filter-in-door7-undefined-undefined-5.jpgr-in-door7-undefined-undefined-5.jpg" alt="beltswitchI REPLACED IDLER PULLY ON SAMSUNG DRYER #DV40J3000 - beltswitcht 5-undefined-undefined-9.jpgndefined-5.jpg" class="h_mi" />
SOURCE: need a picture diagram of
this diagram should help u a far bit
thanks from chris
http://daewooautopartspr.com/_wsn/page15.html
SOURCE: I just replaced a belt
i would check the wiring to the door,light switch, 3 wires, if i remember its GREY/WHITE/Brown. also if that was wired incoirrectly you may have blown a fuse check you outlet for power
SOURCE: I have a 1997 Jimmy. I smelled rubber burning,
Just an idler, probably has a frozen bearing, you will need to get it repaired.
COULD BE A BAD BEARING IN THE IDLER PULLY OR THE TENSIONER ON THE TIMING BELT OR THE SERPENTINE BELT. IF ITS A SQUEEL IT MAY BE SOME COOLANT GOT ON THE SERPENTINE BELT. TRY TO WASH THE BELT WITH WATER AND LET DRY COMPLETELY. IF NOISE REMAINS RETURN TO THE SHOP THAT DID THE WORK.
