Televison & Video Logo
Jeff Smalley Posted on Jan 31, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung Television (Model No.: un40eh5000fxzc) that recently kicked the proverbial bucket.
The LED on the front of the set blinks red and in rhythm (not an error code like some Samsung TVs do) along with the backlight. Initially, I thought it was the power supply, however, all of the board voltages are within spec but only if I unplug the edge connector which provides the current to drive the backlight. Leaning on the side of caution, I replaced the P/S unit anyway thinking the primary drive circuit or the secondary tap for the LED array may have been weak under load. Unfortunately, the same issue persisted with the new board. So my questions are; has anyone run across this issue before and if so, what was the resolution? Secondly, has anyone actually found that the LED array was defective and required replacing? I should mention, that when the backlight flashes, it appears of the the LED elements light up, albeit briefly. Thanks to anyone that considers my quandary!
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Feb 12, 2020
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006801
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
5 Related Answers
Anonymous
  • 149 Answers
  • Posted on Jan 27, 2008
SOURCE: Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Anonymous
  • 138 Answers
  • Posted on Aug 20, 2008
SOURCE: Philips 42PF9630A/37 PLASMA TV
Replace that board the part number is 996500032643. go to www.vancebaldwin.com for the price of the board.
Paul
  • 225 Answers
  • Posted on Oct 03, 2008
SOURCE: Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Anonymous
  • 106 Answers
  • Posted on Jan 05, 2009
SOURCE: Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Anonymous
  • 95 Answers
  • Posted on Jul 23, 2009
SOURCE: Hello only on screen
On the power supply board I replaced CAP C226 as per another poster and the problem is solved. It is a 470 uF, 35 VDC capacitor. Bought one at Radio Shack for <$1.50 USD. Radio Shack part number is: 272.1030.
Can you help diagnose a tv with no picture or sound? just a baclklit and flashing red indicator light
The red light flashing is indicating the error.
depending on the make and model of the TV, the duration of the flash and number of flashes determines the error code.
Black screen, blinking led
actually, unless the control board is identical(which it isn't) that would be a bit of a stretch.. Let's see..can you let me know what is the model number of your set?
A red power, a green timer, and a red lamp led lights are flashing on t front power panel.
Likely an AKAI DLP made actually by Samsung. All 3 lights blinking is lamp failure. You can fix yourself with owner's manual.
RED STAND/BY LIGHT WILL COME ON BLINK SEVERAL TIMES, HEAR A CLICK SOUND A FEW TIMES BUT TV WILL NOT COME ON,
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
continue f
Sony bravia KDF-50E2010 RED LIGHT FLASHES 4 TIMES THEN 3
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
continue f
2helpful
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
1helpful
Power led blinks red
See recently added Fixya service tip for this model.
Service Bulletin PDP 0068-01 Main Digital pcb see http://www.eserviceinfo.com/download.php?fileid=43450
TV won't come on, the red LED keeps blinking
sounds like you have a solder joint thats touching another one, recheck your solder and make sure theres no broken solder joints else where.
1helpful
2answers
Problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
