Might try a firmware update to see if that fixes it:
https://h30434.www3.hp.com/t5/LaserJet-Printing/Problems-with-HPA9102-HP-PageWide-Pro-477dw-MFP/td-p/6930878
SOURCE: HP 8150N ERROR CODE 79.060E
Power off the printer. Unplug the
printer's USB cable for 5 seconds replug turn on the printer.
If that fails power off the PC and printer unplug the USB cable at
the PC and printer replug and power back on the PC. After PC is
fully booted turn the printer back on. If this keeps
reoccurring please replace the USB cable and or try different USB
ports.
SOURCE: HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
SOURCE: print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access
Piont: My Home Wifi (kaba)
Host : ip address of you
printer
user : Blank ( tried my windows username,no
use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
SOURCE: sir i have a printer in mfp 1522 hp,thats problem
Try doing a nvram. Take out the paper and the toner and turn off, hold down the down arrow and the cancel button and turn the printer back on while still holding. Hold until permanent storage init is displayed.
Al
SOURCE: HeLp! My HP CM2320nf MFP is printing blurry!
I had the same issue... and found this to finally work after reviewing many sites.
System Setup - Print Quality - Adjust Alignment
NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
