SOURCE: Caps Lock Light
If you have the Setpoint software installed from logitech, it will show onscreen when you press caps lock. eg CAPS LOCK ON, or CAPS LOCK OFF when the key is pressed
SOURCE: Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
SOURCE: caps lock won't turn off by pressing the caps lock key
Ok, here ya go.
Start-->Control Panel-->Clock, Language and Region,-->Change keyboards or other input methods
Once the window pops up...
Change Keyboards -->Advance key settings-->Now select "press the CAPS lock key" option
Hit apply and OK.
If this works, don't forget the "fixya" rating! Let me know okay?
SOURCE: How do I reattach a caps lock key?
ok , so i had the same problem just now , and i fixed it , what you need to do is take of the little metal clip that attached to the key , place it in the little slot that are next to the retaner , then place the top part under the retainer , when you do this , the retainer will sort of hang upwards , then put the capslock key back and push it in , it will snap , gave me a headache to do , but it fixed mines , hope i helped you , if anything email me , [email protected]
