Try to solve problem:
https://www.youtube.com/watch?v=pNqq2wPNZbA
If you are using standard weight thread (40 to 80 weight) then you should be at 3 on the loopers and 4 on the needles. Heavier or lighter weight thread will change those settings.
SOURCE: looking for a instruction manual for the elna 634
pl. try this website
http://www.elnausa.com/
SOURCE: I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
SOURCE: I'm having problems with threading my elna 634 overlocker - can any one offer advice?
Are you chaining off when you reach the end of the serged seam? You should be chaining at least 6-8 inches then clipping close to the end of the fabric.
Perhaps I'm not understanding you. What exactly do you mean "coming out of the last loop?"
SOURCE: An Elna 686 overlocker we aare having trouble
I have this manual . I will send it to you. get me your email or an address Thanks cyndee
Testimonial: "Yes Please! My email address is [email protected]. Thank you."
