SOURCE: DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter?
h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML);
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
If this sounds freakishly familiar to recording on a digital cable or
satellite set-top box, you are right. It is exactly like recording a
signal from a digital cable box or satellite receiver. While it may be
inconvenient to perform the steps above, at least the option still
exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except
for recognizing channel 3. The digital converter is a single tuner item
so it only receives one station at a time.
SOURCE: Connect to Converter Box
There are a fews ways of accomplishing this.
On the back of your converter box and TV/VCR there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from the antenna to the (IN) connection on the back of the converter box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the convert box.
Step 3. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful. Please take a moment to rate tis solution.
SOURCE: I have a Sylvania sst4324s tv and would like
At 2 watts, it would run very small speakers without an amp, but I suspect you would be more happy with a home theater amp. There are a number of surprisingly inexpensive models with DVD players in the same unit. Here is an example:
http://www.overstock.com/Electronics/Coby-DVD765-Home-Theater-System/3981690/product.html
Hopes this helps:)
Testimonial: "Thanks for the help farmerbear!"
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
I'm trying to get back my channels and it's not working. I have 2 boosters hooked up they worked for a little bit then one day only 4 stations was working we have an old antenna can't afford a new one.
