You will receive the HP Printer Validation Failed message on your computer when using HP ePrint apps.
A portion of the regular purposes behind the mistake are:
Imperfections in the printer
Befuddled printer driver
Carriage isn't working
Blunder in the product update
A straightforward restart can assist you with investigating the mistake.
SOURCE: hp printer error oxc a8a0201
The 'ink system failure' error is caused by air in the ink feed tubes. This happens if you use poorly filled refilled cartridges or you let the cartridge run all the way to empty and the printer sucks air into the system. You will need to purge the air lines to correct the error. We have a step by step guide to do this in an article posted on our services page at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ You should be back up and printing in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
