Gerald Maritt Posted on Jan 29, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a pioneer vsx-454 audio/video stereo received,when I turn it up it shuts off,how do I fix it
Attique-ur-Rehman
Level 3:
Top Expert:
  • Pioneer Master 2,677 Answers
  • Posted on Apr 14, 2020
Attique-ur-Rehman
Pioneer Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
878084
Points
8006
5 Related Answers
A
Anonymous
  • Posted on May 08, 2008
SOURCE: SPEAKER CONNECTION
problem with connection
Gurudristi
Sachin
  • 98 Answers
  • Posted on Apr 21, 2009
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Anonymous
  • 3 Answers
  • Posted on Jun 14, 2009
SOURCE: Pioneer VSX-454 Receiver
ANY NEW universal REMOTE MADE 1984-2001
Anonymous
  • 5 Answers
  • Posted on Oct 04, 2009
SOURCE: Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Anonymous
  • 2992 Answers
  • Posted on Mar 02, 2010
SOURCE: diagram of pioneer receiver vsx-454 to show wire hookups
This site has the manual for downloading. You need to register but it's free.
Pioneer VSX 454 loses station battery needs replacement where is it located???
Memory is not held by a battery. It is usually held by a capacitor that provides the micro with voltage. Not that easy to change.
How do I connect my pioneer vsx prologic receiver to my hdmi plasma tv?
If the tv has normal stereo outputs, you will use those. if it only has a digital output, your best option will be to buy a new receiver.
4helpful
My Pioneer VSX-454 stereo receiver, put up an "overload" in the display and shut down. I have had this receiver for several years and this is the first time that this has happened. Is the...
The protection circiuts detected false more likely in the audio power amp circuits. Turn off all the speaker outputs or disconnect all the speaker wires to see if the fasle gose away. If it is power amp problem, it will cost way too much to have the shop troubleshoot it down to component level.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
2helpful
Diagram of pioneer receiver vsx-454 to show wire hookups
1helpful
Hi there. Need some help. I love my pioneer
Get an RCA-to-whatever-size-the-headphone-output-on-the-IPOD-is adapter and jack it into any available aux or line level input.
3helpful
I have a Pioneer VSX-454 reciever, both 1.25 Amp fuses blown
blue two legged varacter on power supply board needs to be replaced
I have pioneer receiver Vsx-454 i want to know if this receiver is 5.1 surrounds
Yes. It is 5.1 surround. There are 2 front channels, 1 center channel, and 2 rear channels which comprise the "5" in 5.1 surround. The pre-amp output channel for a sub is the ".5".
2helpful
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
