SOURCE: When I turn on the treadmill and insert the key FF
what type of treadmill is it
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: I bought a Gold's Gym 450 Treadmil that won't turn on
You can try to get it from the store where you had purchased it or try to search it online.
SOURCE: Gold's Gym Crosswalk 650 Treadmill belt stops
Hello.
Either there is too much load for the motor, or the motor is weak, or the controller in failing and unable to adjust for changes in resistance.
By far the most common problem is too much load. Do the checks in your manual to be sure the walk belt is not too tight or dry. Also check that the motor belt is not too tight, you should be able to twist it 90 degrees. If you loosen both belts until they just begin to slip and then retest you might find the everything is okay which indicates the walk belt may need lubing or replacing. If the walk board under belt looks pitted, grooved, or distorted it also would need replacing.
If the unit passes the tests above and a push test then the problem will be in the motor or controller or possibly both. If the motor passes a walk/voltage output test then it might be okay and you might only need a controller. Unfortunately, it is common for a failed motor to damage a controller and vice versa, and that damage might not show up immediately, so you if one has failed you might consider replacing both.
SOURCE: WHEN I TURN ON THE
Your upper console electronics are no longer functioning. The upper electronics are around $300.00 to replace. Go to http://www.iconservice.com/ and then click on "replacement parts" and then input Proform 695 to view part needed to correct the "FF" code problem: http://www.iconservice.com/CustomerService/parts.do
SOURCE: i need the manual from golds gym crosswalk 570
go to www.iconservice.com give you model, etc and download for free.
sincerely. Happey new Year.
ernesto cuadra
managua, nicaragua
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
