When you say shopping you mean Stalling right. If yes then the usual cause is a failing Relay 109 which is the main power relay . The early golf had a grey relay which failed due to dry solder joints etc the modified black relay was issued to elevate the issue.
Relay 109 supplies power to these ,
Glow plug relay
- Fuse 32
ECM
Fuel quantity adjuster
- Fuse 34
Cold start injector
Waste gate bypass regulator valve (N75)
Change over valve (N239)
EGR vacuum regulator valve (N18)
Mass air flow sensor (G70)
- Fuse 43
Clutch vacuum vent valve (if equipped)
Brake vacuum vent valve
Relays for preheating coolant (if equipped)
Crankcase ventilation heating element
The ECM supplies power (and sometime ground as well) for:
Fuel cutoff valve
Cruise control switch
Manifold (intake) air pressure/Intake air temperature sensor
Needle lift sensor
Engine speed sensor
Engine coolant sensor
Closed throttle position switch (part of "go" pedal)
Kickdown switch (part of "go" pedal)
Throttle position switch (part of "go" pedal)
Fuel temperature sensor
Modulating piston displacement sensor
The ECM also communicates to the instrument cluster electronics and transmission control module (on automatics).
As a result of this, you can see why if the relay starts to cause power to flicker, or voltage drops, for all of these components, the results can be "unpredicatable" and none of them desireable.
according to haynes beetle repair the code is turbocharger boost pressure control valve positive deviation. to trouble shoot
check the wiring, connecting pipes.using a hand held vacuum pump apply vacuum to the wastegate actuator,(with engine not running) check the actuator arm and lever for freedom of movement , disconnect the electrical connector from the boost pressure control valve. using an ohmmeter check the solenoid windings for an open circuit, the boost pressure control valve should measure about 25 to 35 ohms if excessive resistance or open circuit is indicated replace control valve.
a scan tool is required for a complete diagnosis of the system control circuits some may be rented from a local auto repair store hope this helps and norrows it down for ya
