Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
You might check at the link below for a code but nearly all 'universal' remotes really aren't universal.
Before replacing a failed original remote, get makes and model numbers of those you have seen, then check on line for the code tables to avoid buying one that will not work with your gear.
1 800 Remotes Factory original replacement remote controls
