If the status from the printing source writes "paused" despite the green tick, there are a few possible reasons why this may be happening:
Printer software: The printer software may be set to pause the print job. Check the printer software settings to see if there are any options to pause the print job.
Print queue: The print job may be paused in the print queue. Check the print queue on your computer or device to see if the print job is paused. If it is, try resuming the print job.
Paper jam: A paper jam can cause the printer to pause the print job. Check the printer for any paper jams and clear them if necessary.
Low ink or toner: If the printer is low on ink or toner, it may pause the print job. Check the ink or toner levels and replace them if necessary.
Connectivity issues: Connectivity issues between the printer and the computer or device can also cause the print job to pause. Check the connection between the printer and the computer or device and make sure it is properly established.
If you're unsure about any of these steps or are not comfortable troubleshooting the printer on your own, it's always best to contact the printer manufacturer or a professional technician for assistance. They can help diagnose and fix the problem safely and effectively.
https://printcopy.info > brand=Kyocera > code=7900
Kyocera FS4100DN Ā· Code: 7900 Ā· Description: Drum unit EEPROM error. No response is issued from the device in reading/writing for 5 ms or more and this problem is ...
Error code c-6000 means fuser error. It would be best to replace the fuser unit as a complete assembly, but sometimes just the thermostat can be replaced, which would be cheaper. Either way, an authorized Kyocera dealer should have these parts.
