Televison & Video Logo
Jon Smith Posted on Jan 28, 2020
The top right corner of my LCD LG TV is fuzzy. I remember the tv being dropped one time in the car. What would be the easiest fix for this. Has something come lose or what is the suspected damage
Nicky Wyatt
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 28, 2020
Nicky Wyatt
Contributor
Level 1:
Answers
Questions
0
Helped
433
Points
5
5 Related Answers
Anonymous
  • 66 Answers
  • Posted on May 15, 2008
SOURCE: Dark screen on TV
This sounds like a speaker got too close to the TV.
Degauss is built into many tv's check for it in the menu.
Otherwise, yes a TV shop or yourself will need to degauss the TV.
Anonymous
  • Posted on Aug 20, 2008
SOURCE: built in tv guide channel
It's possible there is a flaw with your TV but more likely the listing information is being blocked. Many cable companies do this, likely another reason to force you into buy/leasing their equipment. This should not be a problem with OTA.
Anonymous
  • Posted on Feb 19, 2010
SOURCE: Power Only
On the LG TV remote, press either the "return" button or the "exit" button, then press power to turn it off and then power to turn it back on again.
Fixed!
(This happens when some other device remotes send a strange signal to the LG TV, putting it in a service mode).
Anonymous
  • 1056 Answers
  • Posted on May 28, 2011
SOURCE: My son dropped my 32'' inch LG lcd tv now it won't
It probably has a cracked circuit board. If you want to repair it on your own open it up and see if you can find where that cracked section is and see if you can resolder it back properly.
Anonymous
  • 506 Answers
  • Posted on Jul 15, 2011
SOURCE: my 47" LG LCD TV
its no big problem.I implore you visit the user's manual to see how to zoom and undo it. Get back if you encounter further problems.
Service menu
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Service mode enter, adjust and exit procedure to many brand TVs, including LG; are given in detail.
Lg tc fuzzy panel
What is the exact model number to your LG TV?
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 800 posts to different brand TVs now.
2helpful
LG - 32LD350 - 32" LCD TV - 720p is the type of tv
Hello
It has been permanantly damaged, and is not repairable. To get it work perfectly, you have to replace the screen. OK.
8helpful
2answers
Crossed out speaker symbol on my LG screen won't go away
If your TV is connected to a VBOX, i other words you have virgin box connected to it, thats the problem. If you try and set your vbox remote to control volume of your tv it will go, or u can start configuring and abandon, will also get rid of it
24helpful
2answers
Power Only
Fixed!
Little transparent box with 2 in top right hand corner of screen
I found a suggested solution, reboot the cable box (unplugging & replugging) and the mysterious #2 box should disappear.
Plasma tv screen going black
pls contact 9420806154 for solution
3helpful
2answers
Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
Built in tv guide channel
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
