SOURCE: JVC video recorder - replacing rubber band
Not spinning disc If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A Unable to detect discs The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A) Dew indicator is on permanently. Cannot play or record tapes. No dew present - caused by internal fault This Camcorder uses very fragile flexible circuits to interconnect the PCB's. They plug in to edge connectors. It seems that when they made these camcorders at the factory, they had as many problems getting these film flexy circuits back into the connectors as us service engineers have. I saw one unit that had a crease in the flexy circuit which had caused a hair-line fracture. Solution, trace the wiring and solder a sub-miniature wire across the broken track. Don't disturb any flexy connectors that you don't need to. This camcorder is a **** to work on Not loading properly Usually due to incorrect head alignment or dirty head, or failure of LM324 op-amp Doesn't record properly, ie: looks like one channel is down when recorded, pre-recorded tapes are ok Check Q008 for dry joints
SOURCE: CR01 will not drain.
hi had the same problem due to a build up of hair and a bobble stuck in the pump easiest way to the pump is to take the the front off take the top off first four screws on front panel at the top un due circuit board prize off outer door two screws behind hinge lift front cover up and you can get easy accsess to pump. hope this helps
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
SOURCE: Replacing bands
Since the belts control the timing of the mechanism, I would not recommend this as a home repair. While relatively simple compared to some, this still is a delicate repair that can easily go wrong. Please bring this unit to an audio repair shop. Expect a parts cost in the $15-$20 range. There are 3 belts inside.
Dan
¡æThe drain pump filter
• The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
