I suspect the answer is that it's just dead, but here we go anyway. We have had this unit from rather a number of years ago, recorded several vhs to dvd successfully, and then it stopped working entirely. When I power it up it cycles through "Hello, setup, ch 3", but there is no sound from the unit at all - nothing seems to power up or start other than the display. It's thrown the F04 and F06 errors, but I've cleared those. They reproduce any time I try to put in a tape, which the unit doesn't recognize nor do any of the gears engage to intake the tape. The DVD tray is unresponsive to anything either. It feels like none of the actual components is receiving power, but I can't identify anything wrong with the internal connections (I've taken it apart to a point). Anyone have any suggestions?
SOURCE: panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
SOURCE: I have lost my instructions to record vhs to dvd
Here is the instruction manual download site at Panasonic. Hard place to find what you need. Hope this helps.
http://www2.panasonic.com/consumer-electronics/support/DVD-Recorders/model.DMR-ES35VS
SOURCE: Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code-
free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
SOURCE: getting an U99 error with
The U99 error is a "general communications problem". Were you trying to switch sources when you were recording? You shouldn't to avoid this error. That's what we did with my Uncles unit.
