Televison & Video Logo
Shane Wigum Posted on Jan 27, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use the bulb from an older sony rear projection on a newer sony LCD projection tv.
Dariusz Zalewski
Level 3:
  • Master 1,095 Answers
  • Posted on Jan 27, 2020
Dariusz Zalewski
Master
Level 3:
Answers
1095
Questions
0
Helped
297541
Points
3055
Only if that is same bulb #
5 Related Answers
Anonymous
  • 579 Answers
  • Posted on Dec 31, 2007
SOURCE: Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Anonymous
  • 4402 Answers
  • Posted on Jul 07, 2008
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Anonymous
  • 505 Answers
  • Posted on Dec 09, 2008
SOURCE: 6 red blinks wont turn on sony rear lcd projection
thermal fuse. it sits below the lamp and has popped. replace with new fuse or just short (eliminating fire protection) let me know if you need instructions.
Anonymous
  • 5138 Answers
  • Posted on Dec 25, 2008
SOURCE: sony kp-51ws520 what bulb does it take
Tube numbers on tubes.Red Green Blue?
Anonymous
  • 10594 Answers
  • Posted on Jan 26, 2009
SOURCE: REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
The brightness fluctuates during programs
If it an older LCD, it is back lit with a bulb. The newer TV all say LED TVs. If it says that, these are also LCD tvs, using LED for back lighting.
2helpful
Sony rear projection lcd hd tv 46 inch...the replacement bulb indicator popped on ....i bought a bulb but haven't replaced it yet. now i see a 1 inch rainbow strip across the top of the tv. from end to...
Replacing the bulb won't fix this problem. This is a defect in the optical block, which is apparently fairly common.
The best way to get in contact with the team that can fix this problem is by facebook. While on facebook, type "I have a defective Sony TV" in the search bar. This will bring up a page that is moderated by the SonyListens Team.
Post a comment about your TV, be sure to list your model number and a description of what's wrong with it. Someone within a few days will give you more information as to what steps to take next. It will seem like a lot of hoops to jump through, but in the end will be worth the time it took, as Sony will offer you huge discounts on a newer TV (I recently went through this, and got a new 3D ready TV for about a quarter of it's suggested retail value). If you are not on facebook, they list a contact email address as [email protected]
Also worth noting: if you have receipts for recent repairs or replacement bulbs, you can submit them along with the other info, and Sony should adjust the offer price to compensate.
One word of warning though, once you have started this process and have received an offer from Sony, you will only have a week to claim the offer, so make sure you have the funds to put down on a new TV before you start.
Hope this helps! :-)
My sony is turning on and off when I turn it on. The picture and sound appear and disappear. What is wrong and do you have the part..
The most common cause of picture disappearing and returning in a Sony LCD Rear Projection TV is a faulty bulb. Replacing the bulb is the first step in troubleshooting this type of problem in KDS-60A2000 and all other Sony Rear Projection LCD TVs.
Sony Lamp Gallery
shows all Models and Lamps for Sony Rear Projection LCD TVs. KDS-60A2000 uses XL-5200U Lamp.
easyab
1helpful
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
If a Sony rear projection Tv is showing a red shadow on type is it the bulbs?
This problem is very common with rear projection TV's.
It is related to one or more of the colour guns (Bulbs) being out of alignment. The only way to correct this issue is to have a technician come in and fix it or bring it into a repair center. I personally would suggest purchasing a new TV. The cost of getting them aligned is usually more then a basic LCD.
Hope this helps
Dustin
1helpful
Can i order a new lamp cover piece for my sony
Call Encompass Parts Distrubtion or Look it up online at their website
1-800-638-3328.
I own a 46 inch sony Bravia and have noticed white spots on the corner edges when a black screen is up. Ithought it might have been the surround speakers too close as in the older stlye tv being affected...
All LCD TVs (except the newer LED versions) are back lite on the edges of the TV. Depending on how faint the image is you may simply be noticing the lights. Try adjusting the backlight or brightness.
Without an image this is the best I can do.
Just wondering when to replace the blulbs on my Toshiba 57H81 CRT
Hello, Im Ismail A, and I would love to help you with your problem. Ok, well you should change your bulb every 2 years.
LCD Sony TV - Skwiggly line
Hey there I think the problem is coming from your LCD chips not your bulb, the bulb has nothing to do with the color or skwiggly lines it just shoots out white light,your LCD chips are burnt and the problem will not stop by changing your light bulb you need to replace the OPTICAL BLOCK the skwiggly line will just get worst with time
hope this helps
please rate this solution !!!!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
