SOURCE: Sharp MX 2300n - When
PRESS #*c* in your control console respectively then you will get a service mode,Check to
confirm that there is A3 paper in the paper feed tray. If paper is
insufficient, supply it, will ask for main code press 67 then press Start and machine will ask for a sub code
press 24, then machine will give you another
display press execute on that one, you will get a pattern print out. After
completion of self-printing, the display is shifted to the output patch scan
start standby screen. Make sure toplace the printed test pattern on the glass pointing the light
side of the pattern towards the left hand side that is to place the light side
coinsiding with the arrow marking on the glass table, place some white A3 sheet
above this to correct the white value, press service and then press execute then
machine will give you another print out then on that you press ok on that one
and wait for the below display message.
PRINTER
ENGINE HALFTONE AUTO ADJUSTMENT MODE COMPLETED
THIS PROCEDURE. PLEASE
QUIT THIS MODE. After this
press CA button on your console and check the copy, repeat the same procedure
for 4 or 5 times if the copy quality needs to be get improved. Rate this and vote for this
SOURCE: network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
