SOURCE: pull clutch on arctic cat 700 snowmobile
you must buy the correct puller from a jobber or from artic cat dealer. it looks like a long threaded bolt that screws into the center of the clutch do not attemp to remove any other way you will damage the clutch or even worse the crank shaft. these pullers are usually around 25.00$
SOURCE: when replace a stator on a 1998 ZL 500 arctic Cat
i have a 1998 arctic cat zl 500, i think that i have an issue with my stator, i was wondering if it possible to test it without pulling anything apart just with the wires coming from the housing
SOURCE: replace battery on 2007 arctic cat 500 with 84 miles on it. Now
I have Artic Cat 500 it was fine when i parked it about two weeks ago but now it turns over but won't start any solutions
SOURCE: carburater schematics diagram for a 2004 arctic cat 300
Go to http://www.arcticcatpartshouse.com/arctic-cat-atv-parts.aspx?aribrand=ARC#/Arctic_Cat/2004_ATV_300_4X4_GREEN_MRP_%28A2004ATF4AUSS%29/CARBURETOR/A2004ATF4AUSS/A2004ATF4AUSR.
