Question about Acomdata Computers & Internet
Acomdata rocket pod just clicks - Acomdata Computers & Internet
  • Acomdata Master
  • 5,736 Answers
At 16 years old it is dead.
ask a shop to fix it, or upgrade. (get the Seagate external HDD)
Posted on Jan 26, 2020
MP3 Rocket 6.4.10 doesn't open on windows 8.1
I right clicked on "Free Download Now" then clicked on "save link as". Then went to that file & right clicked "open as administrator" it took me directly to the Mp3 Rocket downloader & installed fine. MP3 Rocket is the fastest MP3 converter out there love it converts...
Aug 08, 2014 | MP3 Rocket
Cannot RESTORE data!
Right click my computer...go to manage...then to disk management. What is the status of your disk? Is it online?
Feb 03, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    Wont load music to download
    Best solution update your MP3 Rocket program to a newer version. The installation for the latest version of MP3 Rocket will remove any previous versions of the program installed on your computer. You do not need to uninstall the program prior to updating.... Do not click on "Continue" on the MP3 Rocket home page if you want the free version of the software. Clicking on "Continue" brings you to a page to sign up for the Pro version, which can cost you up to $35. To get the free version, click on the word "download" at the bottom of the page.
    Feb 12, 2014 | MP3 Rocket
    I have 3 Rocketpods and they don't work on Windows 7. Built circa 2004. Now what. Can't find a driver suitable with plug and play. Thanks.
    If it doesn't show up in my computer but does show up in the device manager Right-click on My Computer. Select Manage in the pop-up menu. In the Computer Management window, select Storage, then select Disk Management. In the Disk Management window, you should see a list of available storage devices. Look for the Disk that has a capacity closest to your Drive. Right-click on the right-hand box; in the pop-up menu select Delete Partition. Once you do this, it will say "Online" & "Unallocated". Right-click on the box and select Create New Partition in the pop-up menu. When the Partition Wizard appears, select Primary Partition and click on Next. You will see a default value for the Drive; click Next. You will then see a drive letter (you can change this drive letter if you wish); click Next. You will then be asked to format the Drive.
    May 08, 2011 | Acomdata Rocket POD External Hard 120 GB...
    Acomdata is only clicking but is not being recognized by computer
    Sorry to inform you, that once your hard drive clicks, it's already dead and unusable. It is called the "Click of Death" for hard drives.
    You may want to try bringing your HD to the nearest data recovery center and see if they could recover the files from the HD to another media.
    Thank you and good luck!
    Aug 03, 2010 | Acomdata Computers & Internet
    Will not turn on. Power cord has green light when not plugged into pod, blinks lightly when plugged in.
    The blinking is indicative of a failure within the pod itself. Take the pod to your local PC shop and have the techs there transfer the drive into a new enclosure, if it works there you're in luck, buy the new enclosure and you're up and running again. If not the drive itself may be the issue, if this is the case, respond with your location(Country, State and City) and I will be happy to connect you with a pro in your region to assist you with retrieving your data.
    Hope this helps FixYa,
    Chris
    Sep 29, 2009 | Acomdata 250GB Ext Rocket Pod HDD USB Hard...
    Computers & Internet Logo
    20 people viewed this question
    Top Acomdata Computers & Internet Experts
    Ekse
    Lucky
    ChinthakaJ
    ChinthakaJ
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
