SOURCE: Air compressor leak
If this hole looks factory drilled thats what the valve is for and is weak and needs to be replaced if someone has drilled it into the valve it will still need to be replaced
SOURCE: Pressure won't build up in tank
Your compressor is the oilless type that incorporates a vinyl/teflon piston ring and a cylinder that is open from the bottom. Remove the cover and push the piston to upmost position. Look for scratches along the upper portion of cylinder. If scratched, compression is leaking thru ring and will not fill tank. Replace with Sears part #k0650 cylinder /piston ring kit to restore full power. While the compressor is apart examing the valve plate and reed valves for wear. If worn replace with part #z-ac-0032. Reed valves tend to crack or loose their shape reducing efficiency. If cylinder and ring are in fair condition, then most likely reed/valve plate is the problem. Good luck and email if you have more questions.
SOURCE: The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
SOURCE: Compressor is building up pressure very slow.
It could very well be the valve plate however before you order parts take a look at the cylinders. Unplug the unit, remove the cover from crank side and turn the compressor by hand till the/a piston is at top of stroke. Examine upper cylinder for scratches /wear or failed vinyl piston ring. On oil-free compressors, dirt and grit is sucked-in from the bottom of the cylinder and causes leaks between cylinder wall and piston. If scratched, air pressure is leaking down thru cylinder wall. Failed reed valves cause a pulsation at the intake port (air seems to be pumped out the intake). If you see a model number anywhere on the pump that begins with " WL", your pump is made by Campbell Hausfeld. Parts can be ordered from www.chpower.com. other-wise order parts from sears parts. Cylinder kits are around $40. Good Luck on the repair and email if you have questions.
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
