Televison & Video Logo
Rowena Davis Posted on Jan 25, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Trinitron TV. My DVD/Blu-ray stopped working so I bought a new one. I didn’t think to check the connection requirements and found out that the new player had only an HMDI port instead of component video outputs. So I purchased an adapter cable and I have good audio but there are only horizontal dashes and wavy lines. Can I adjust this? I’ve tried altering picture aspects in the video menu with no luck
Vernon Taylor
Level 3:
  • Sony Master 7,446 Answers
  • Posted on Sep 10, 2020
 Vernon Taylor
Sony Master
Level 3:
Answers
7446
Questions
0
Helped
1960320
Points
26207
An almost complete guess that you are feeding digital into a tv that is incapable of processing it.
HDMI is digital only and an adaptor lead won't convert the signal to analogue. Digital to analogue converters are available but how successful they are I have no experience...
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Jun 24, 2007
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Anonymous
  • 10 Answers
  • Posted on Jan 08, 2009
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Anonymous
  • 51 Answers
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Anonymous
  • Posted on Jan 10, 2009
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Joaquim Martins
  • 1128 Answers
  • Posted on Feb 19, 2010
SOURCE: My Sony Blu-ray DVD player isn't working with my LG HD TV
needs a HDMI™ (V1.3), tv set , or above. try to check the lg tv set is compatible to HDMI™ (V1.3).
Testimonial: "Thanks for the advice but I got it fixed myself, I had the Video Output set wrong."
1helpful
I have bought a new Blu-Ray player, a BDP-S570, which I am trying to connect to my LG TV. The TV is a 50PX4D and has one HDMI port that I have previously used to connect a Sky HD box to with excellent...
There are no compatibility issues. In your BluRays HDMI audio settings set the audio out to PCM instead of bit stream.The TV cannot decode digital bit stream audio.
Just bought a new dvd - Sony player tells me disk is invalid
In most cases, the issue might be with the Java content on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click hear to download the latest firmware update available for your Blu-ray Player:
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service. Please let me know if you require any further assistance with installation or need any clarification. It is my pleasure assisting
I have a 5 year old KLH DVD player. I had it hooked up through AV cable to a 6 year old SONY Trinitron 37" TV & it worked fine. I am now trying to hook it up to a new Westinghouse flat screen TV...
double check the wires are in the correct connections on both the tv and dvd player also the KHL dvd player may need to be put in progressive scan. Usually the red wire for video and the one for audio get plugged into the wrong input and causes this issue
1helpful
2answers
Connecting digital converter,Emerson VCR/DVD Combo,Sony SDTV
I think you may need an RF Modulator. This device will have connections for the DVD and TV and will have a channel 3/4 switch. Good luck to you.
1helpful
I bought a new DVD and it won't play in my sony blu-ray.
I had a similar problem and I solved my issue by upgrading the firmware to the latest version. Full instructions can be found on the Sony site.
2answers
I think a connectivity problem with tv and dvd player
dvd playes or hd dvd players will not play blu ray diskd you must have a blue ray player to play blu ray disks
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
