Tablets & eReaders Logo
Shannon Wilson Posted on Jan 24, 2020
My maxwest tab 9100 android 4.0 is stuck on the loading screen
JamesT
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 28, 2020
JamesT
Contributor
Level 1:
Answers
Questions
0
Helped
5129
Points
Powering off the monior or in your case Force shutting it down could be an option or remove of the batterie. Other is Could be a connection error in the wiring pannel.
2answers
Maxwest Astro 8R. I forgot my code on my tablet. How do I bypass that please?
You can't bypass it. You can only Hard Reset it, which scrubs it clean and reloads the operating system with no code. It is a standard Android OS Reset.
How to do a hard reset on MAXWEST Astro 8Q?
HardReset.info https://www.hardreset.info > devices > maxwest-astro-8q
How to hard reset MAXWEST Astro 8Q ; Here use Volume Up and Power buttons together at the same time until MAXWEST logo appears. ; If you see the Android Robot on ...
Maxwest tab-9155 won't load past android screen
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
How can I get my Maxwest Tab-9100 to charge?
This can happen when a faulty charger isn't providing enough voltage/current. Faulty chargers can provide enough power to trigger the 'Charging' indicator and maybe even to power the unit but not enough to energise the units charger circuit. Try another charger (same voltage) or charging it through the USB socket.
2answers
Maxwest tab 7150
Maxwest Tab 7150 has password locked and needs to be unlocked please, thank you
Android tablet screen freezes
I have an apple android tablet and it freezes at the android with black backround
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
