My i7s tws wireless air pods don't turn on it charges and everything but doenst turn on
    Top Expert:
  • Audio Player... Master
  • 30,888 Answers
How do I pair both i7 TWS earbuds? I can only get one to work
After connecting one, turn on the other. Then while both are powered on? Press and hold the button on both earbuds until they connect to one another.
Jan 04, 2018 | Audio Players & Recorders
I got a new Lenovo Y460p i7 2630 QM last week. Everything else appears to be working fine, but the laptop has issues with the wireless internet. Although, it works fine on LAN, and my other laptop connects...
On the front of the laptop, you will notice a switch. It turns the wireless on and off for airport security etc.. make sure it is on - pc icon with brackets on each side....good luck!
Jun 13, 2011 | Lenovo IdeaPad Y460p Laptop Computer -...
Connection to I Pod touch from PC desktop computer Unable to connect
1.- You must verify that the desktop computer works without problem in wireless way with the D-Link device.-
2.- The I Pod touch device is an external unit to the desktop computer, so you have be shure of the first condition.-
3.- If the destop computer don`t work in wireless conditions, the fail is in the configuration of the LanWireless, you must check both, D-Link device and computer configurations.-
4.- If the computer works ok, the problem is only in the I Pod touch only.- You muts to check fisical connections and I Pod hardware.-
Sep 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
Will not charge, Ipod nano says that this accessory is not supported and shows that it wont charge the battery. also the Teac will not turn off the Ipod or turn it on or it just keeps running . Use to work...
Apple does this so that only Certified accessories have to software to make the hardware circuits charge an i pod, thats especially a problem with some sound docks, my i pod 2 gen works with only 1 of the 3 sound docks that i have tried, but i have a bluetooth i home so i play my music wirelessly
Oct 18, 2009 | Computers & Internet
Not enough compression to spray thompson water
Maybe just plugged. If it has the nozzle that can be rotated 180 degrees, roll it and try to spray. Sometimes a bit of debris gets in there and stops it up. If no on the rotatable nozzle, take the tip off and try to push liquid back to the container, or a waste bucket, to clear the line. You also may need to clean the tip. One last item.....since you sprayed water.....if you chased the water with the TWS, you may have made an emulsion. If so, remove the spray gun, and turn on the pump, pumping into a waste container, until the emulsion is displaced. Clean the gun. I'd say that if it'll spray water, TWS would be even easier.
Regards, --W/D--
Aug 03, 2009 | Wagner Air Tools & Compressors
Intermittent A/C problem
Your system is low on refrigerant, you may also have a leak. AC service runs $100-150,
May 25, 2009 | 1996 Volvo 850
I pod wont turn on
i have put my ipod to be recharged but its taking too long and dosent seems to be charging
Apr 11, 2008 | Apple Mini IPod
UHG!
your computer has its own personal i-tunes for your i-pod and all your music is saved to that computer so if you plug your i-pod into someone elses computer it will eighther sync all thier music to your i-pod or it will erase all the music on your i-pod they dont have on thier computer...my sujjestion is to buy a plug in to the wall charger for your i-pod if your barely home to charge it. that way you keep your music yet charge your i-pod to.
Dec 26, 2007 | Apple iPod nano 2nd Generation MP3 Player
22 people viewed this question
Ekse
 Grubhead
Grubhead
