SOURCE: Kenmore two way tumble action washing machine - shakes, vibrates very loud
sounds like you have a broken stantion on the back of the basket.you can confirm this by opening the door and trying to pull up on the stainless steel basket.if it pushes up and flops back down,that is what you have.if the mach is over 2yrs old,look in your manual under warranty.if it has a 10yr on stainless steel basket and lifetime on tub,you will only have to pay for labor on repair.if it only has 1yr on entire mach,est would be higher than the price of a new one.
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
SOURCE: AC unit on Viking popup is loud and vibrating
take the cover off the front of unit and look down inside at the blower wheel see if there is something in it
SOURCE: loud banging noise during spin cycle on front
Could be a broken spring on top of the drum allowing it to hit back of casing...hope you fix...
