Https://www.manualslib.com/manual/701485/Sharp-21v-R70m.html?page=9#
Check the whole manual, there is high voltage in this unit that can kill you. There is also the inherent production of X-rays due the tube. Please heed all warnings and use the proper tools and equipment because you are adjusting the HV section.
SOURCE: what is the code of
Hello
You are asking about the universal remote code for Sharp I assumes, and place this solution before you.
Three digit universal remote codes for Sharp are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote codes for Sharp are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
SOURCE: I need a user manual
Here a site that you should be able to find user manuals...eserviceinfo.com
the tv goes to "safe mode" to avoid damage to the main board, your problem should be related to a bad caps on the power supply due the tv turns on and off
hope that this help u out
http://www.bostonrecycling.net/
SOURCE: sharp service menu model 21v-fk220m and model 21v-fk200m
Sharp, Fisher & Sanyo will have same configuration to circuit. So, the service menu entry method to these sets will also be the same. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
SOURCE: i have a crt tv sharp model:21v-fw150m blk.. is
Try to download the repair manual to this TV by internet. It has all details.
try to check abl
