Computers & Internet Logo
b
benjohnson1 Posted on Jan 23, 2020
How Does a WiFi Range Extender Beneficial? - Computers & Internet
Chad Kendall
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jan 23, 2020
Chad Kendall
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
992
Points
23
It will allow you to receive a stronger signal at a greater distance from your router.
3 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Oct 25, 2010
SOURCE: How can I increase my
Try moving the wireless router around and or higher.
If the wireless router is in a different room and the room has concrete walls of foils insulation in the walls, this will weaken the wireless signal. AND/OR
You can connect add a antenna to your computer. Have a look at this device. Normal 0 USB High Gain Antennas www.pricewatch.com/gallery/networking/high_gain_antenna
urlftp
Joe Brady
  • 300 Answers
  • Posted on Dec 02, 2010
SOURCE: I cant connect my wifi range extender to my
your range extender is damaged.. replace asap.
Joseph Wright
  • 1729 Answers
  • Posted on Apr 29, 2018
SOURCE: Just installed the OptiCover Range Extender and now my speeds to connected devices is slower that going directly to my WIFI modem. What is wrong?
Did you connect to the new device? It should have a different ID.
How to setup wifiextender benefits of wifi range extender
<h1>Benefit</h1>
A WiFiextender increases the range a wireless signal travels from a router through a wired connection. Because WiFiextenders are wired, they provide stable, strong connection points to your network.
<h1>How To Setup Wifi Extender</h1>
Without WPS it may take a little longer to connect your wifi extender, but the idea is the same. First, you'll want to connect the end of your Ethernet cable, or Cat5 cable, into the Internet port on the extender and the other end into the Internet port on your wifi router.
If you've had the same internet setup for awhile and you didn't set it up yourself, don't panic. You can setup a wifi extender on your own. Can't remember what the Ethernet cable is? It's typically the blue cord.
The next step is to connect the Ethernet cable into the LAN port on the extender and the other end into an Ethernet port on any computer that has a connection to your network. After you launch your web browser, type the IP address of the wifi extender into the address field (or address bar). This is when it's handy to hang onto the instructions as you will find the address in the manual.
After you have entered the extender's IP address, the configuration page will open, and you should click wireless settings, enter your wireless network name in the SSID box, and then save. Next, click on wireless security, select the security type (like WEP), type in the password, and then save. Keep in mind that your options may be different depending on your operating system, but if done correctly, you will have successfully setup your wifi extender.
After you unplug your Ethernet cords from the extender and router, you should plan on positioning your extender within an acceptable range from your router.
IS THERE A WAY TO EXTEND THE RANGE? MY OFFICE IS JUST FOUR FEET OUT THE RANGE
Extend what range? WiFi? If so...yes. You can buy a Wifi range extender from a place like Amazon for as little as 20 USD.
Amazon com WiFi range extender Electronics
Semper Fi,
Z
Comcast changed my wireless password and now my netgear extender doe not work
You will need to reconfigure your extender, check the manual or online at the link bellow.
Since your extender is not working your range is diminished.
WiFi Range Extenders
2answers
I cant setup my belkin wifi extender
Kindly match the wifi settings of the router to extender and give a static ip to extender in range to router lan ip
Grand Canyon Tech
Grand Canyon Tech
