Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Dear Ankit
Thanks.
If you are worried about opening the printer or welding, you can simply buy an easy reset chip from Amazon or eBay. No welding is required and the installation takes only 1 or 2 min. Just peel and stick the chip.
Search for DRUM RESET CHIP or PEEL STICK DRUM RESET and you will find many premade reset chips.
The drum fills up with waste toner and you can empty it but its messy and you need to clean everything carefully after taking it apart. Take out the imaging unit, unloosen the screws on both sides, unmount the retainer springs and push the center pin out of the drum. Take out the drum and unscrew the two screws that were hidden behind the drum. Now take away all parts so that you can empty the waste drum container. Clean everything especially the light emitting panel, drum and white plastic cover needs to be clean. Hope this helps.
Reset DCP 7030 drum unit : -LCD- Press MENU and turn on printer - MAINTENANCE arrows 81 and OK -RESET DRUM COUNT press OK -RESET LIFE COUNT press CLEAR / BACK arrows 99 and OK ready
