What you can do since there aren't any schematics available, would be to measure the 1 half and write down the resistance and do the same with the other half and add them together. You should go up a little also, say if you are reading 1 k ohm, use a 1.2k ohm in it's place. The other way is to follow it upstream to see what the resistor is supporting. If it's an I.C. you could look up the I.C. number and go to website to see what resistor is required to support that I.C.
