Usually a number 2 Phillip's screw holds the two halves. Look for several holes (sunken) on backside. Note location of any screws of any significant difference in length. Unplug power cord, foot pedal, and remove accessory draw first.
When reinstalling screws, first turn counterclockwise until screw threads sit into existing housing threads, then tighten.
SOURCE: Singer 7469 Confidence sewing machine instruction
Make sure that the right large dial (which is the drive wheel for the motor) is engaged. You might have it set for winding a bobbin and the needle will not go down unless you have the right wheel pushed in.
Testimonial: "thank-you that was a fast reply when I really need one."
SOURCE: I NEED THE PIECE THAT COVERS THE BOBBIN on the Scholastic Singer
You can order the part from a Singer parts center:
http://www.singerco.com/support/replacement_parts_ssc_list.html
SOURCE: How do I reset the timing between the upper and lower shafts?
Email me and I will attach instructions but remind me of your problem. [email protected]
SOURCE: My sewing machine is brand new- Singer confidence.
I am having exactly the same problem. I called the Singer helpline and was on hold for 28 minutes before I gave up. I emailed them instead. Did you ever figure out what was going on?
SOURCE: Singer Confidence 7463 - needle
Have you changed the needle since you purchased it? A needle should be replaced every 4-6 hours of stitching so for each garment sewn as a rule of thumb. So try replacing the needle, cleaning and oiling the maachine as per the manual. Check needle is in the correct way, it is easy to put in backwards if you aren't familar with them, flat shank to the back and there is usually a scarf (cut away area) at the back of the needle which is where the rotary hook under the needle plate comes around to catch the upper thread during the stitch process. So if needle is in backwards this will cause stitching to fail.
So elimate the needle firstly.
If this fails and the knocking noise continues, then it could be that the timing has been knocked out. It can happen if you sew over a pin and hit it hard (or the needle strikes the foot if stitch setup is wrong for the foot being used). In this case, you'll need to take it back to the shop for the serviceman to fix.
