Question about The Office Equipment & Supplies
My printer is set to prompt me for a code when I print. now it doesn't prompt me for a code. Now I get an error on the printer saying that it can't print because it did not get a code number.
etaf
wayne walker
  • 779 Answers
SOURCE: my lexmark x4650 is supposed to print wirelessly.
reset the network connections Procedure: Resetting the Network Settings
  1. Press Setup ().
  2. Press the right or left arrow button until Network Setup is displayed, and then press .
  3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, and then press .
  4. Press the right or left arrow button to display Yes, and then press .
  5. Observe the message "Clearing Wireless Settings".
  6. NOTE: You will not be able to navigate the menu until this process is complete and the Wi-Fi light resets from to orange ().
http://support.lexmark.com/index?page=content&id=HO3371&actp=search&viewlocale=en_US&userlocale=EN_GB&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4650&searchid=1270310780939
Guides available from this link http://support.lexmark.com/index?locale=en&segment=SUPPORTproductCode%3D&startover=y&userlocale=EN_GB&question=Lexmark_X4650&productCode=LEXMARK_X4650&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X4650&searchid=1270310775279#3
Network Guide available from here - under documentaion http://support.lexmark.com/index?page=content&actp=PUBS&locale=en&segment=SUPPORTproductCode=&userlocale=EN_GB&id=PU45811&productCode=LEXMARK_X4650
Use guide http://support.lexmark.com/index?page=content&actp=PUBS&locale=en&segment=SUPPORTproductCode=&userlocale=EN_GB&id=PU45810&productCode=LEXMARK_X4650
Posted on Apr 03, 2010
Cannon ir c3180i printer prompting e000021-0003
This error code means that the develop unit wont rotate, although I have also had this error code when the drum unit wasn't replaced, did it tell you to replace the photoconductor?
May 02, 2012 | Cannon Office Equipment & Supplies
Printer says ' catridge error, refer to device documenation.' the catridge is was just refilled and the printer has been woirking all along
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP Officejet 4315v All-In-One InkJet...
I get a reading in the window of the printer that says Cartridge error. and then on the screen it says cartridge is misaligned. What gives?
  • Connectivity :
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
It says an error has occured in the configuraion and I need to fix the problem and start again. I do not know how to find out what the error is so I can fix it. This error box opens up when I hit the...
  • Connectivity :
Oct 26, 2010 | HP LaserJet 1020 Printer
Error in printing
there is a printer options at control panel, try to see if the setting is printing immediately,...
Jun 17, 2009 | Epson laser Printer EPL-6200L Laser
Says Ink system failure
Here are the steps that i want you to follow exactly to resolve your isse.
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. Thank you so much. adonscott
Jul 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error with printer
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If this does not work, contact HP technical support for assistance.
Jan 13, 2008 | HP PSC 2355 All-In-One InkJet Printer
Since installing my printer I have a error code of 3610 and 3501
Go to the Kodak.com website and follow their prompts to reach Customer Support for the AiO Printer(s).
Had similar issues with mine and they resolved my problem overnite by sending me a replacement part.
Jan 01, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board.
Dec 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
22 people viewed this question
Top The Office Equipment & Supplies Experts
Thomas F. Schneider
Keith Love
James Cagle
James Cagle
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
