Question about HP Office Equipment & Supplies
How I do fix Hp Printer Error 0xc05d1281? - HP Office Equipment & Supplies
    Sergeant:
  • 288 Answers
HP Printer Error Code 0xc05d1281 is generally occurring when the Ink System Failure has failed.
Solution 1:- Unplug the printer
  1. Unplug the power from behind the printer by disconnecting all the power cable from the source.
  2. Wait at least 2-3 minutes.
  3. Then connect the power cable again.
By Caitlin Dunn HP Printer Error Code 0xc05d1281 is generally occurring when the Ink System Failure has failed. The other causes to happening this error include a Problem with Printhead, Printer Failure, and hardware failure, etc. If your HP printer had a paper jam and now is displaying Ink System Failure 0xc05d1281, you are unable to print, scan, copy, and receive faxes, then don't need to worry about it. As it's suggested by the HP tech support team, this Error Code 0xc05d1281 can be easily fixed with the simple troubleshooting steps. Here, the blog will guide you very easy steps on Fix HP Printer Error Code 0xc05d1281?, then follow the steps which given below.
Solutions to Fix HP Printer Error Code 0xc05d1281:- Solution 1:- Unplug the printer
  • Unplug the power from behind the printer by disconnecting all the power cable from the source.
  • Wait at least 2-3 minutes.
  • Then connect the power cable again.
Now, check the error is resolved; if not then, go to the next solution.
Solution 2:- Clean Head You should try to check and clean the head contact pin condition of the carriage unit.
  • Verify that it's correct cartridge for your HP printer or not.
  • Check all the Cable connection, especially the carriage FFC.
If the Error Code 0xc05d1281 continues displaying, then you should go to the next solution.
Related Blog: How to Fix HP Printer Error Code 0XB80D8128? Solution 3:- Reset Printer
  • Unplug the power cord from the back of the HP All-in-One.
  • Then wait for the unit to go to the sleep mode.
  • Wait for 60 seconds.
  • Press and hold Print "Photos & Photo Fix" buttons simultaneously on the control panel; keep them pressed and reconnect the power cord to the All-in-One.
  • Now, continue pressing the buttons while the display goes blank or Reset shows on the control panel display.
Solution 4: Perform Carriage Task You should try to check and your Printer carriage and perform some task by the following way.
  • Turn off the power of your HP Printer.
  • Open the panel.
  • Turn on the power.
  • Wait for print carriage to start moving to the left.
  • Let it go past halfway.
  • Before print carriage reaches to left-hand side shuts the cover.
  • Leave the Printer turned on.
Solution 5-: Perform Print Head Task
  • Unplug the power cable of the HP Printer.
  • Then open the printer.
  • Next, push the whole print head mechanic to the center
  • While the printer still open, plug the power and turn it ON.
  • Once the printhead still moving and is going to the very LEFT, close the cover.
  • Wait for some time, until its boot up.
Now try to gain start the printer and check the Error Code 0xc05d1281 is resolved.
After performing all the above steps, still, if you are getting the same error code, then you should contact HP Customer Support professionals for the comprehensive guidance &advice
Posted on Jan 22, 2020
Anonymous
SOURCE:
STP162
Sandy Chamberlain
  • 132 Answers
SOURCE: HP 3310 All In One Error
Try to reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turns itself back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartridges in the printer so that it can reset.
Posted on Nov 01, 2007
NinaE
  • 3278 Answers
SOURCE: MY PRINTER WON'T PRINT ERROR CODE 0XC05D1281
First, be certain there are no tiny pieces of paper in your printer, left from the paper jam.
Then, you need to reset your printer - try:
1. Unplug from the power cord.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power check the functionality.
And, if the above doesn't fix:
1. Unplug the power cord from the back.
2. Wait for the unit to go to the sleep mode. Wait for 60 seconds.
3. Press and hold Print Photos & Photo Fix
buttons simultaneously on the control panel; keep them pressed and reconnect the power cord.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
Good luck.
Posted on Jul 04, 2009
Anonymous
SOURCE: Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
Posted on Sep 15, 2009
Buddy Mcsparrin
  • 1684 Answers
SOURCE: display says error 0xc05d1281
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
bandana_gyrl
Sarah McDonald
  • 181 Answers
SOURCE: I have a HP c7280 printer, which is making funny
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Jan 21, 2010
HP c8180 error code oxc05d1281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d1281-Error-code-for-Photosmart-C8180/td-p/1212853
Apr 10, 2015 | HP Office Equipment & Supplies
HPPhotosmart 3210 AIO hangs us with error code of 0xc05d1281
Hi Minnie,
This could be because of residue on the Printhead electrical contacts
Try the steps below and it should help.
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the Cartridge with lint free cloth. ( Golden dots )
6. Turn on the printer and it should say " Cartridge missing or need to be reinstalled "
7. Install the Cartridges and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 16, 2013 | HP Photosmart 3210 All-In-One InkJet...
Error 0xc05d1281 HP Photosmart D7160 InkJet Printer
The best solution is don't buy another HP printer, get away from the inkjet printers all together they'll nickel and dime you to death! Go with a laser printer, why do you think over 75% of business use them instead of inkjet printers?
Jan 31, 2012 | Office Equipment & Supplies
Display says error 0xc05d1281
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
May 20, 2009 | HP Photosmart C8180 InkJet Printer
Ink failure
put ink cartridges in the printer
Jul 20, 2017 | HP Photosmart C7280 Laser Printer
What is error 0xc05d1281
Apparently its a Ink System Failure. Here's an email thread for comment for HP C6180 with error 0xc05d1281 => http://www.fixyourownprinter.com/forums/printer/50063
It's posted somewhere in the middle of the thread.
Here's a solution to reset your printer to factory defaults without using your ink for recalibration.
1. Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed above, starting with pressing the * and # key.
5. After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
Dec 31, 2008 | HP Photosmart C5180 All-In-One InkJet...
29 people viewed this question
Ekse
Thomas F. Schneider
