HelloTechhttps://www.hellotech.com > Home > Smart Home
To connect Alexa to a new WiFi network, open the Alexa app and tap Devices. Then select Echo & Alexa and choose the Alexa device you want to connect to a new ...
Chromecast receives a wifi signal. Are you still broadcasting a wifi signal? Is SSID the same? Is it the same band. .. 2.4 or 5 g? If the wifi all matches, then you can reset the chromecast by holding the black reset button down for 20-30 seconds. Reinstall the latest google home app on a smartphone and follow the setup instructions on the app.
?Can you change a wifi Ipad for a sim card....I don't understand your question......you can change a spare tire for a flat tire, but a wifi Ipad is much larger than an sim card and the two have completely separate uses.
There are several "free" apps for iPad/iPhone printing. Mostly quirky. I have had luck with : Epson iPrint, iCan Print, and Epson Printer finder. Its best if your printer is wifi ready. This gives it an IP address and is more easily connected to your iDevice.
As far as I have tried, every wifi printer worked for me, you should only configure it properly. Most printers doesn't connect to existing wifi - they create their own unprotected network and you will be able to print only when connected to that network. To avoid changing networks every time you want to print, you should connect your printer using USB cable to a PC and configure it to connect to your existing wifi network, then you will be able to print and surf the web on the same wifi network.
You may need to change the configuration of the router to use B/G/N compatibility mode using the 2.4GHz spectrum instead of the N-Only mode using the 5GHz spectrum.
On page 30 of the user manual available at the TrendNet web site, the Wireless >> Basic web page settings has a choice of "802.11 Mode". For your situation, you will want to use the "Mixed 802.11n, 802.11g, and 802.11b" setting.
