There are steps to solve brother printer error code 76. Go through these steps and solve this brother printer. No single step is hard to implement. Read and go-ahead to implement on your device.
Step 1:-Firstly, Turn of the Brother Printer
Step 2:- Then switch on the Brother Printer device while keeping all the way down to the "menu" button until all the led are flashing On/Off. Now you are in "protection" mode.
Step 3:- Next, press "eighty" button.
Step 4:- Then press the "mono begin" button several times till you see for elimination: xxxx
Step 5:- Next, press "2783" button on the way to reset the purge counter. You will see removal: 0000
Step 6:- Then press the "stop" button.
Step 7:- Press "ninety nine" to go out the protection mode.
Now test the error is resolved.
SOURCE: brother fax machine intellifax 2600
Fuser or overheat error it will probably be followed by a 77. Menu, mode and 0 quickly in that order will give access to user maintenace mode (lights will flash once your into the mode). Hit 91 to reset the machine. If this doesn't work you have a major problem with your fuser unit and it will need to be replaced. DO NOT DO THE ABOVE PROCEDURE MORE THAN ONCE AS YOU WILL START TO MELT STUFF IF THERE IS A MAJOR PROBLEM.
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
SOURCE: Brother MFC 9030
Open the printer and check to see it your fuser is worm up. Do not touch the fuser. If it is cold. you have a problem.
You fuser may be at end of life. Need to be replaced.
cost price of fuser and labor will come close or above cost price of machine. your choice.
Good luck
SOURCE: getting error 1628
Upgrade to Windows
Installer version 2 or newer version. To do this, follow these
steps:
1. Start Microsoft Internet Explorer, and then
browse to the following Microsoft Web site:
http://msdn.microsoft.com/downloads
2. In the left pane
tree menu, click "Setup and System Administration", and
then click "Setup".
3. Click "Windows
Installer", and then click the appropriate link for your
operating system.
4. Click "Download" to
download and install Windows Installer version 2 or newer version.
SOURCE: my printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
